MSI Neo2 Plat [1.C3 Bios]
Opteron 170
2GB G.Skill HZ
SI-120 & Panaflo L1A
Hey guys,
Above are my specs. I have seen to run into a fairly odd issue with my motherboard(s). I'm going to be using FSB instead of HTT simply because I think it's an easier read
To cut to the chase, I can't POST at a FSB > 250.
I'm fine from 200-250. But from 251 and up I simply cannot POST. Yet, in windows, on of my motherboards is good until about 280 FSB and the other, 330 FSB via clockgen.
I'm basically trying to see how high my memory can go but I can't load up memtest to try it. I'm using these settings when attempting to post.
HT Link = 3x
CPU multi = 5x
FSB = 260
Vcore = 1.4v
vdimm = 2.6v
AGP = 67
At this point, I attempt to boot up from floppy and it will not POST. I then have to reset my CMOS, and re-apply the BIOS changes. I then tried:
HT Link = 3x
CPU multi = 9x
FSB = 260
Vcore = 1.45v
vdimm = 2.6v
AGP = 67
Same thing happens. Therefore, I'm assuming it's a similar bug to the "220 and higher" FSB on the Neo4 Plat.
However, is there ANYTHING else I should try? I actually have TWO of these systems with the SAME setup and NEITHER can boot above 250FSB. I'd REALLY like to think I'm doing something wrong.
Any help is appreciated.
Thanks
Opteron 170
2GB G.Skill HZ
Hey guys,
HT Link = 3x
CPU multi = 5x
FSB = 260
Vcore = 1.4v
vdimm = 2.6v
AGP = 67
HT Link = 3x
CPU multi = 9x
FSB = 260
Vcore = 1.45v
vdimm = 2.6v
AGP = 67
Thanks
