So heres the deal: I'll use overdrive to set my GPU clock from the default 669 to around 740. Also, I'll set my memory clock from the default 829 to around 1000.
I can run an acceptable temperature with perfect stability at this clock.
The problem is that it doesn't seem like it's doing anything at all. I have tried with numerous games (Bioshock, HG:L, CoD4 etc.) and I don't gain ANY framerate benefits (I'm serious...not even a single frames difference).
So, my heat goes up, it reads that it's using all the overclocked resources on the card when I'm in game...but I don't gain a single frame. Baffling.
Also, I've tried from 7.10 to 7.12 CCC and all had the same result. I've also tried Rivatuner, same result.
This one stumps me...help please.
