Hey, My system is as follows.
ASUS Rampage x48
Ultra 120 Extreme Cooler
DDR 2 Corsair Dominator 1066MHZ 2x2GB
Q9450 OEM
I tried to overclock using the AI Siute utility and I pushed it to 2.8, 3, 3.2, 3.4 and when I run ASUS probe 2 it puts the following in red. The following shows information without Overclock and then with the FSB at 425 resulting in 3.4ghz
No OC
Vcore
1.17v
+3.3
3.25v
+5
4.99v
+12
12.10v
SB
1.09v
SB2
1.57v
FSBT
1.20v
DRAM
1.97v
DRAM REF
0.98v
NB
1.38v
CPU
22oc
MB
26oc
NB
33oc
SB
35oc
With OC to 3.4ghz
Vcore
1.22v
+3.3
3.25v
+5
4.94v
+12
12.10v
SB
1.09v
SB2
1.57v
FSBT (RED)
1.39v
DRAM (RED)
2.22v
DRAM REF (RED)
1.10v
NB (RED)
1.65v
CPU
23oc
MB
25oc
NB
38oc
SB
35oc
Firstly, Is the board/temp/volts running good without overclocking? As I had to mess about with the heatsink for ages and was worried I damaged the thermal pastes bond to the Heatsink?
I read somewhere the auto is setting the ones in red at a higher volt than they need, can you recommend how I go forward?
Thanks alot
ATLANT3AN
ASUS Rampage x48
Q9450 OEM
No OC
Vcore
1.17v
+3.3
3.25v
+5
4.99v
+12
12.10v
SB
1.09v
SB2
1.57v
FSBT
1.20v
DRAM
1.97v
DRAM REF
0.98v
NB
1.38v
CPU
22oc
MB
26oc
NB
33oc
SB
35oc
With OC to 3.4ghz
Vcore
1.22v
+3.3
3.25v
+5
4.94v
+12
12.10v
SB
1.09v
SB2
1.57v
FSBT (RED)
1.39v
DRAM (RED)
2.22v
DRAM REF (RED)
1.10v
NB (RED)
1.65v
CPU
23oc
MB
25oc
NB
38oc
SB
35oc
Thanks alot
ATLANT3AN
