Hey Hardforum
I'm new to overclocking, and I decided to start with my video card. I'm using EVGA precision, and furmark.
First question: When you run furmark, do you just leave the stability test running until it reaches a constant temperature?
2nd : what should the maximum temperature be, of both the PCB and GPU
3rd: is there any harm in ramping up the fan speed
4th : should I leave the core clock and shader clock linked, or OC them seperately
5th: any other programs I should run to test stability etc?
If there are any other tips, they would be much appreciated
Thanks Hardforum!
Thanks Hardforum!
