Overclocking/ Ram Timmings Help
shyheim
Ok well this is my 1st time overclocking i think i understand what to do. I need some help with the ram timmings. i have got it Oc'd to 2.2ghz from 1.8. So i am doing good so far. I am using stock cooling. my goal is 2.4, but after i try to go past 2.2 ie 2.3 it doesnt boot.I think it is the ram timmings.but i dont know what to change.
here are my current settings:
RAM:
Auto Config: Manual
Dram CAS Latency: CL 2.0
RAS Active Time: 8T
RAS Precharge Time: 4T
RAS To CAS Delay: 4T
DRAM Bank Interleaving: Enabled (Default)
CPU x9
CPU Clock 245mhz (200-300)
Dram Clock 211 mhz (any higher it will not boot, i lowered it from 245 and it booted)
Vcore: 1.42
Vram 2.65 (default)
Stock Cooling
Cpu Temp: 47-48 Max load 52-53
system Temp: 34-35
I am basically stuck i dont know much about the ram timmings and the computer will not boot if i set the clock to 256 x9 3.0 so i need some help on how to achieve my goal of 2.4ghz. I am sure a lot of you guys can help me out with the ram timmings Thank you.
:confused: :confused: :confused: :confused:
tornadotsunamilife said:
Well I'm certainly no expert at this but maybe it's more to do with voltage rather than timings?
well yea i have tried upping the voltage but doesnt do anything but i dont know about the ram settiings so i havent touched them. i even lowerd the ram fsb again and that did nothing too. I think it is the the ram timmings that are holding me back. but the 2.2ghz benchmarks are good i am happy so fair. but i know it can go more :)
Ok i just tried upping the vram from 2.65 -default to the next on up (2.75v) still doesnt boot :mad:
What brand and model mem?
What brand and model mobo?
You should reduce your CAS latency from the looks of it. try 2.5 or 3
yeah, that cas latency kinda jumps out at me too...
though rig specs are definitly a requirement for any constructive feedback from me :p :D
I agree with ecplipse... but try lowering cas to 3.0 and leave the rest and upp ram voltage to 2.9 then try. With cas at 3 them timings are quite loose so i dont think it would be timings but eclipse will know for sure:D
I think with those kind of timings and voltage he could easily hit 2.4 they need tightening up a bit (voltage for a start, 2.9???)
I was just saying those timings and voltages because then i could see if he can even get past 2.4 then he could tighten them
SpoogeMonkey said:
It would help ALOT if we knew what cpu you are oc'ing, what mobo, ram, etc you have.
Ok sorry
Specs:
CPU amd 64 3000 venice core
Mobo is JetWay A210GDMS-Pro Socket 939
RAM OCZ Performance Series 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory
Cas Latency 2
Timing 2-3-3-6
Voltage 2.6V
ok i tried 9x256
Ram clock at 222mhz and 189mhz
vcore 1.45
Cas 3.0
Vram 2.75
Still doesnt boot.
I have tried everything you guys have said so far and it cant get it to boot. i can goto 250x9 but if i try 255 it doesnt boot.
yea at 250x9 video games freeze up and what not so. i dont not about that i even bumped the vcore up some still freezes. so i put it back to 2.2
I have tried raising the vcore to 1.50 + doesnt boot.
i have tried changing the cas to 3.0 and raising the ram volt doesnt boot.
i have tried lowering the ram clock to 156 mhz and 216 mhz w/ vcore raised and cas 3.0 doesnt boot.
So any imput would be great i dont really know what else to do.
Any suggestions on changing the ram timmings? would that do anything i dont know.
i have read on here awhile back when i was looking into getting this mobo and i have seen ppl hit 2.5. 2.4 and they say there onboard nic card goes out. but i know it is possible.
I got a question dealing with ram timmings, my stock kingston hyper x pc3200 came stock at 2-2-2-5 and i set them to 2.5-3-3-6 @ 2.7volts at a 1:1 ratio my computer is clocked at 3.4ghz from a 3.0ghz p4. is this considered pretty good with the ram? i checked cpu-z and my ram is running at 227|227 1:1.
I think you would be ok to set it back to 1 and manually set ram timings to2-3-3-6. Also, have you taken the ram out of the picture yet (run ddr200 / 1:2 divider, set ht to 3x) and tried to find the max the cpu can do?
