aeonrevolution
- Aug 30, 2004
First off heres what I am working with.
CPU-Z Report
CPU-Z version 1.27.2.
CPU(s)
Number of CPUs 1
Name Intel Pentium 4
Code Name Northwood
Specification Intel(R) Pentium(R) 4 CPU 2.66GHz
Family / Model / Stepping F 2 9
Extended Family / Model 0 0
Brand ID 9
Package mPGA-478
Core Stepping D1
Technology 0.13 µ
Supported Instructions Sets MMX, SSE, SSE2
CPU Clock Speed 2660.0 MHz
Clock multiplier x 20.0
Front Side Bus Frequency 133.0 MHz
Bus Speed 532.0 MHz
L1 Data Cache 8 KBytes, 4-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 512 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 2660.0 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
Mainboard and chipset
Motherboard manufacturer Dell Computer Corp.
Motherboard model 0F4491
BIOS vendor Dell Computer Corporation
BIOS revision A06
BIOS release date 10/08/2003
Chipset Intel i865P/PE/G/i848P rev. A2
Southbridge Intel 82801EB (ICH5) rev. 2
FSB Select 533 MHz
Performance Mode enabled
Graphic Interface AGP
AGP Status enabled, rev. 3.0
AGP Data Transfert Rate 8x
AGP Max Rate 8x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 128 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 512 MBytes
DRAM Frequency 166.2 MHz
FSB
RAM 4:5
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 7 clocks
# of memory modules 2
Module 0 DDR-SDRAM PC2700 - 256 MBytes
Module 1 DDR-SDRAM PC2700 - 256 MBytes
Software
Windows version Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
DirectX version 9.0c
I know there wouldn't be a ton of improvement but for the hell of experience I was wondering if it was worth overclocking my cpu and/or memory. I play CS:S pretty much solely now and get more than playable framerates so that isn't an issue. I just wanted to give overclocking a try ya know heh. Anyways I was browsing around cpuid.com and I couldn't figure out which set my board would fall under. Here is the link for the available ones. www.cpuid.com/clockgen.php
If anyone has any help or comments lemme know.
CPU-Z Report
CPU(s)
Number of CPUs 1
Code Name Northwood
Brand ID 9
Package mPGA-478
Core Stepping D1
Technology 0.13 µ
Bus Speed 532.0 MHz
L2 Location On Chip
BIOS revision A06
FSB Select 533 MHz
AGP Max Rate 8x
Memory
DRAM Type DDR-SDRAM
FSB
Software
