Hi,
Here are the specs on the machine.
Gigabyte P35-DS3R
E6420 Currently 3.2GHz with 1.29V
Crucial Ballistix PC6400
Nvidia 7800 GTX PCI E
Seagate 250GB SATA
X-FI Gamer sound
2 Optical Drives
PSU is a Antec Earthwatts 430 WATT 29A on (2) 12V rails. The CPU is currently running at 3.2 GHz. The video card is stock clock.
I believe my PSU is holding back the overclock. I can get the system stable at 3.45GHz using 1.46 volts before load and 1.43 during load using Orthos. However, I can inch that OC up further but not as stable over time. So I am attempting to run 3.6 GHz. The machine will boot with no problems. I can get into XP, no problems. My V core is around 1.48 before load. The problem I have is when I go into a load like Orthos it will run for several minutes and the system will automatically reboot.
From the information I have seen on this site and others, leads me to think the PSU is getting hammered too much. I am thinking from the generic wattage calculators the PSU is pushed right to the 80% mark. What should the true head room for OCing be?
I know how to overclock. However, I am trying to determine if the PSU might be holding the CPU back or the CPU does not clock as high as I thought.
Later,
shaggy
Gigabyte P35-DS3R
Seagate 250GB SATA
X-FI Gamer sound
2 Optical Drives
Later,
shaggy
