I just tried overclocking my Desktop PC which is running a E8400 Wolfdale Intel 3.0 Ghz processor on a Gigabyte EP43 motherboard. I intended to get the processor all the way up to 3.8 but I started off with the first test at 3.2 and I encountered a problem.
I basically followed the following hardforum thread:
http://www.hardforum.com/showthread.php?t=1169366
I had set the clock ratio at 9x which was max and the frequency at 356 mhz.
The problem that I encountered was that as soon as I restarted after setting to 3.20 ghz was that the whole thing started making a lound whine noise. So I just let it start up anyway but it just goes to the loading user applications screen and then pretty much just freezes at that screen. I then set back all the clocks to defaults and everything to default and tried starting it up but this time there was no whine noise yet the computer would still just freeze up at the loading your personal settings screen. I tried resetting via taking out the battery on the motherboard and putting it back in and same problem persists.
Any help would be appreciated greatly. I just need it to run properly on normal settings at the least forget overclocking.
Thanks guys
Thanks guys
