shivang222
- Dec 31, 2006
Okay so I turn on my computer and go into the BIOS and read the CPU Freq in Mhz and it says it is at 3666 mhz and the cpu multiplier is at 11x... well, my cpu is the QX6850 and I have not overclocked it at all so it should be running at 3000mhz right?
Also, my cpu temps are around 50 degrees celcius in the BIOS ( i know it is high)... if that means anything
My CPU core voltage is set at 1.41V when on the box it says that max voltage is 1.35v
