Hello,
I've got a question about overclocking a Pentium 4 3.4 EE LGA775 and running his bus speed at the same speed as the DDR memory (running synchronic).
Say that you've got DDR2-667 (PC2 - 5300) and you wanna run the CPU bus speed at the same speed as the memory. Then you need to run your P4 at 166MHz bus speed (quad pumped). Right?
So say you want to overclock that CPU to 3.8GHz, then u need this lineup??:
"3400 @ 3818 MHz (166 * 23)" Can you like get that high multiplier on an unlocked version?
