Hello all and thanks in advance for your input.
I am wondering if any of you mad OC guru's have found gains in Ocing the PCI E bus? I host a thread with my clan and found a member who is using Ntune ( a tool I do not use) to get higher PCI E bus speeds. 2500 to 2850. How does this effect those of us using SATA and is (Ocing in BIOS) worth looking into for better performance.
Lets take for example a system like this
A8N32 SLI
4800 2X
OCZ 4000 Platnium
X2 XFX 7900 GTX ultra's
X2 Raptors
TT Armor Case
OCZ 700 Watt GE PSU
All on Air.
A side note has anyone found a way to break the 2600 Mhz. barrier on air with the 4800? If so settings would be appreciated.
A8N32 SLI
4800 2X
OCZ 4000 Platnium
X2 Raptors
TT Armor Case
OCZ 700 Watt GE PSU
All on Air.
