Overclocking P4 2.8ghz, Advice needed
morpheus9394
Hi,
I have just ordered my first P4 upgrade, to replace my aging AMD 1900+.
I have been seeing that alot of people are getting great overclocks with the P4 so I was wondering if someone could point me in the right direction, with some advice or tips or good web links.
My new parts are:
P4 2.8ghz Hyperthreading
Abit IC7
Corsair Twinx 1gb 3200 low latency
Seagate 120gb 7200.7 SATA HDD
AKASA KING COPPER 901 cooler
My case has 6 80mm case fans, 3 blowing air in and 3 sucking hot air out, so heat should not be a problem, especially with that AKASA cooler.
I also have a HIS ICE 9800, which has an very good cooler & exhaust system to keep it alot cooler than other 9800s and I have overclocking that already, but not really pushing it hard (465 core, 365 memory)
If anyone has got optimal bios settings for my new board, especially in regards to memory timings, I would be very grateful.
Thanks in advanced.
Depends on what youre going to do with the system, just experiment with upping the FSB, if it is unstable, go up with the voltage, dont go over 2.0V though or your chip is gonna go fast. Run some CPU Intensive programs, or Prime95 to find out if its stable.
