Shakes McQueen
- May 27, 2014
Hey Guys,
So I've built my last few computers myself, but never had the nerve to dive into CPU overclocking. With my latest build, I've decided I'd like to give it a try (see specs in my sig). Forgive me if I begin to ramble past this point
Basically, I'd just like some advice on how far you think I could comfortably go, with the cooling I've got. I'm not looking to push the envelope too far, but just want a "comfortable" overclock that won't kill my CPU, and will be very stable.
Right now, my CPU idles between 25-30C, and tops out around 50C under load. I've replaced the stock fans on the Corsair H100i cooler with a pair of Corsair SP120 Quiet Edition PWM fans (push config), and replaced two of the three case fans with a pair of 140mm Noctua PWMs.
My ASUS board actually comes with a TPU switch for "automatic" CPU overclocking, but I've read that automatic mobo overclocking often sets the voltage unnecessarily high, so I've stayed away from it thus far.
My question is basically what CPU ratio you think I could comfortably get away with, plus what voltage you'd recommend, as well as any other advice you've got. Thanks!
