I have overclocked my Pentium 4 Prescott CPU (socket 478) from 3 to 3.6 GHz one week ago and had no problems so far. Since I've bought a Thermaltake Big Typhoon cooler just for the purpose of overclocking, it's actually cooler than it was with stock fan & frequency. Upon starting the computer, SpeedFan reports temperature of 32-38 C, and even playing Oblivion for a while won't raise to more than 42-43 C. It will increase to 50 C after only 10 minutes of running CPU stability test (found at http://www.majorgeeks.com/download215.html) however. With stock speed and cooling, temperatures were between 50-60 C so I think I'm safe (and hopefully someone here will tell me if I'm not
). CPU-Z reports my FSB: DRAM ratio as 5:4 (unchangeable in BIOS), so my memory is running at 385 MHz (seen in both CPU-Z and Everest Home Edition) instead of desired 398 MHz (240x1,66).
The only things I did to achive overclocking was:
a) changing FSB frequency from 200 to 240 MHz
b) changing memory/CPU frequency ratio from 2.0 to 1.66 (although this wasn't even required, as BIOS changed it automatically), since I don't want to fry my RAM - BIOS and EasyTune 5 show my RAM frequency as running at 398 MHz, but, as I've already mentioned, CPU-Z and Everest show 385 MHz - if this is correct, should I increase FSB frequency a bit more to put the memory frequency back to default of 400 MHz (or is it even worth it?) - since my motherboard won't let me change vcore, I don't know if I can push it much further anyway.
My motherboard is this one:
http://www.gigabyte.com.tw/Products...w.aspx?ProductID=1648&ModelName=GA-8IPE1000MK
