Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
From what i understand about overclocking Intel chips that are locked is that your only options are to configure the ram speed, and ratios if the options there, ram voltage, and cpu voltage, and the fsb.
For instance, on my lil brothers PC that i just put together.
ASUS P5P800-VM
Intel Pentium D 805 @ 2.66
OCZ 2x512mb Premier series
Gigabyte 9600 PRO 256MB ( had it laying around the house)
I set the Memory to 2.5-3-3-7 ( which is what the memory is specified at)
DRAM Voltage to 2.8V
CPU Core to 1.5V
and I slowly upped the fsb and running OCZ Memtest and then Windows to check for stability.
So far, using a Zalman 7000B-CU LED cooler, I am Prime stable @ 3.4GHz. Which isnt bad at all considering the system is dirt cheap!
I suggest setting the ram to its default specs, and then slowly up the FSB and the CPU VCORE until u achieve a stable OC, just remember to check on the temperatures of the chip, you dont want to fry it now
