Overclocking my P4M
StealthyFish
Hey, what do you think I would get in terms of overclocking for this setup?
Sapphire 100148 Radeon X1600Pro - $121.00 ( - 15.00 rebate) (+4.65) http://www.newegg.com/Product/Product.asp?Item=N82E16814102666
Wintec AMPO 512mb DDR 400 - $36.99 x2 (+4.81) http://www.newegg.com/Product/Product.asp?Item=N82E16820161615
MSI 865PE NEO2-V SOcket 478 ATX Motherboard - $67.99 (+4.85) http://www.newegg.com/Product/Product.asp?Item=N82E16813130467
Thermaltake TR2 430W Power Supply - $39.99 ( - 15.00 rebate) (+ free shipping) http://www.newegg.com/Product/Product.asp?Item=N82E16817153023
AeroCool HT-101 70mm Blue UV CPU Heatsink - $39.99 (+4.99) http://www.newegg.com/Product/Product.asp?Item=N82E16835183107
what speed is ur p4m? is it northwood core or prescott?
if its northwood then the max multi would be 12x as speedstep is not available on the board and would get u to about 2.4GHz if you run the cpu at 200MHz fsb with ur board and a bit of voltage (not alot but a little bit more than stock)
if its a prescott then u can run your cpu up to 4GHz cuz you can use RM Clock to increase or decrease the multi from 14x - whatever the multi shouldve been for your cpu.
In my case i had a 3.06GHz Prescott P4M and multi was 23x but i got the cpu up to 4.2GHz using 200MHz FSB and 21x multi
works beautifully for the time that i had that agp system
every p4-m is a northwood. they all have a core voltage of 1.3v. the highest core clock is 2.6ghz. If we're talking about a mobile p4, thats a different story...
yea, lol, sry. It's a Pentium 4 M 3.06ghz Northwood, yes, i checked it, it said northwood. But hell, I might be wrong. On the chip, it says:
Intel '02
Pentium 4
3.06ghz/512k/533
SL726 Malay
L321B437
M328b120
0271
Sounds like a celly, but i've heard northwood's have that amount of cache. It's a Pentium 4 M, atleast that's what dell said when I was lookin at it's specs. (it's a Dell 5150 processor. usin it since the motherboard crapped out one day)
Mobile P4 and P4M are basically the same i would not differ the name
