Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have 2 X 1GB Crucial Ballistix 6400 Ram and have it running at 444Mhz 4-4-4-12, I was wondering if running it at the same 444Mhz but changing the timings to 5-5-5-15 would make it any better/quicker??? Thanks for any help!
its not stable at 4-4-4-12 at 1066.. because i own this memory.. its 5-5-5-15 @ 1066 and your talking about nano seconds slower here people.. you wouldnt even notice it and at 1066 it would be = to or faster on the majority of things compared to 4-4-4-12 @ 800mhz.. since the standard for all 1066 is 5-5-5-15.. unless your buying rediculously fast memory that is 4-5-5-15 1066..
your not going to notice a difference at all between them.. and even on my system i score better on 3dmark06 with it at 1066 5-5-5-15 then i do with it at 800 4-4-4-12.. mind you its only about a 100 point difference..
as crucial and corsair techs have told me before, a higher frequency is always much better than lower timings. 1066 with timings like 8-8-8-30 will still probably be better performance (not benchmark) wise, I think.
