cannondale06
- Nov 27, 2007
okay first off try to be nice because I am a noob at this overclocking thing. I am not looking for an insane oc but instead just a small boost. at the moment its not even necessary but I am planning on getting a much faster gpu in a couple of months so I will need to oc the cpu a bit just to keep the bottlenecking to a minimum.
ok some mistakes I have made before was just raising the fsb which actually put the memory at 960 which I hope didnt cause any harm. next I tried to mess with the memory timings a bit but that resulted in no booting, obviously my memory doesnt like any thing higher than 5 4 4 12 which are the standard timings.
ok here are some things that worked. I did figure out the 1:1 thing and got the cpu to 3.6(9x400) with memory running at 5 5 5 18 because I left it set to auto. next I tried 3.8(9.5x400) and it ran just fine for prime95. then I set the memory to 5 4 4 12 and left the cpu at 3.8. I ran prime95 for over 30 minutes with no issues and 52 C max temp.
so the exact settings I am using right now with no issues are:
3.8(9.5x400)
core voltage left at auto and its showing 1.312 to 1.296 at desktop and 1.280 to 1.296 for prime95
memory at 5 4 4 12 timings, 2T, 800mhz with voltage left on auto
pci-e set to 100mhz
I am happy with 3.8 and dont really care to go any higher for the time being. please let me know what else I need to change or alter for best long term stability.
3.8(9.5x400)
pci-e set to 100mhz
