Mar 3, 2007 #1 J JVC [H]ard|Gawd Joined Oct 24, 2004 Messages 1,280 i have an intel d975xbx mainboard. memory is 4x 1gb ddr2 667 sticks. if i overclock, will memory and harddrive and video card, be affected? is there a way to overclock only the cpu, and not the rest of the system (mem+video card+hdd) ??
Mar 3, 2007 #2 O orion23 Gawd Joined Jun 4, 2004 Messages 879 Disable C1E, Speedstep, Thermal Control. Enable PCI Lock or lock the PCI frequency to 33:33 PCI-E Frequency should be set to anywhere between 100 and 105 mhz Set your RAM Speed to 533mhz If you have a Badaxe 1, you need to do a % burn in. 10 to 30% overclock if I remember correctly.
