I "Powerleaped" my 8100 to 2.8Ghz a couple of years ago and now I'm interested in it's overclocking possibilities. I could use some info on what software to use and any other tips from anyone familiar with my setup. Thanks
Only Dells that are overclockable are the XPS 600 700 710 systems. And the newer notebook 1710 systems. Your system is now very old and would not upgrade it any further and save for a system that can be overclocked as mentioned above or another computer vendor.
VelocityMicro Gamer’s Edge PCX
eVGA nForce 680i SLI Socket 775 A1 version
Bios P-25
E6600 core 2 duo 2.4 Ghz @ 3.0 Ghz 1.35v
850 watt p/s
Arctic Cooling Freezer 7 Pro Heatsink
4 Gb Corsair Dominator DDR-2 1066 Mhz Heat Xchange 5-5-5-18 2T
4 gb addressed for 64 bit - 2.8 gb addressed for 32 bit
eVGA 8800 GTX 768 mb @ 660/2000 O/C
SATA 250 Gb WD 16 mb cache
20x Lite On DVD-R
Dell 2407 ( 24 ) LCD
Vista Premium 64 bit
Vista Ultimate 32 bit
3DMks06 11,469
Dell Dim 4400
1 Gb 2100 DDR memory
120 Gb Seagate 7,200 drive
XFX 7800 GS O/C AGP
410 watt p/s
XP Home
