the_cheeky_badger
- Dec 15, 2006
Hi Guys,
I've overclocked my 3.3Ghz 1100T to 3.8ghz using the CPU multiplier only (19x), although it passed the benchmark and stability tests ok with a high temp of 42C, when I start playing GTA IV for a while it eventually blue screens.
I dropped to 18.5x to achieve 3.7Ghz and that seems more stable, however if I wanted to go higher am I correct in thinking it time to start pumping more voltage in? If so, how much should I increment by and what is the ceiling for the Phenom 1100T?
Thanks!
Thanks!
