Hello Everyone
I have decided with this motherboard, I will for once see the absolute max I can overclock. With that said, I am a bit unexperienced in learning say... When my CPU is at its max, or when the voltage is at its max.
I just got done raising my voltage to 1.35v in the BIOS (However CPU-Z still reports 1.113v) and raising the CPU to 3500mhz, however upon running Orthos (And everyone else seems to be fine), Orthos reports:
Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 0 minutes 14 seconds - 1 errors, 0 warnings.
Execution halted.
Which doesnt tell me much - not enough voltage? Too high already ? (doubtful) CPU is at a steady 40 degrees Celcius. Well I raised the voltage, which seemed to do absolutly nothing.
On another Note -
My Memory is rated to run @ 1066 FSB, yet if I try to run that it will pretty much instantly crash (BSOD, no explanation from the errors), thus being forced to leave it @ 800 FSB. In light of that, I have run memtest atleast 3 times overnight, so each was over 8 hours, 25+ Passes, 0 Errors. I dont know how to explain that, if it isn't fixed by next BIOS I will contact Corsair on that part unless you guys have any ideas for this problem either.
Specs:
Intel Core2Duo E6700 w/ Zalman 9700 Heatsink
ABIT IN9 32X-Max
Corsair Dominator 8500C5D
Western Digital 150GB 10,000RPM Raptor
PC Power & Cooling Silencer 750w Power Supply
Execution halted.
On another Note -
Specs:
ABIT IN9 32X-Max
