Overclocking Memory
3erious
i have gube ddr2 667 memory runing at 553 at 4-4-4-12. Is it possible to get lower timings.
P.S my bank cycle time(trc) is untouched at 21 clocks, what does this do and would it make a difference to my system if i lowered it.
thanks
3erious
you have the hardware, only you can answer the question about getting lower timings. try it.
You can just try it, it won't kill anything, just be prepared to hard reset your bios because sometimes when I was messing with mine it wouldn't post...other then that, I have just heard that DDR2 is picky about low timings, so it may not work but won't kill anything.
