overclocking INTEL 915 P4 3.2 Ghz
AKshay87
Is it even possible to overclock from the bios the speed of the FSB,or change the multiplier?
If so please tell me how.I will use air cooling
Um, we need just a little bit more info. What mobo are you using, ram, etc.
stock mobo's usually don't let you oc so depending on what you have, you might be outta luck.
I have original INTEL mobo,775 socket,800Mhz FSB,1Gb kingston(single) DDR SDRAM(3-3-3-8)
