I am trying to overclock my 8800 GTS in Vista Ultimate x64. I have tried a number of programs (Powerstrip, nTune, ATItool..) but none of them works. Are there no tools for GPU overclocking in Vista x64? Why doesn't anybody seem to care?
EDIT: With no real options to overclock, I have considered flashing my videocard BIOS to get an overclock that way, but I have a few concerns:
1. NVflash seems to be incompatible w/ 64 bit windows. I tried running it w/ command prompt but I got the same 64-bit incompatibility error. So unless I am wrong, I would have to install Vista x32 or something to do this.
2. I have never flashed a videocard BIOS before, and there is a good chance I will f* the overclock settings up. For example, how does memory work? I have seen people setting it to 2000 and then people setting it to something like 975... Is the 2GHZ memory clock an *effective* setting, like you would set it to 1000 in the BIOS and it would end up being 2GHZ effective? Or are they really cranking out a ~1.2 GHZ memory overclock?
