Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hello,
Does anyone have a how to for overclocking a 2nd card
in crossfire? I can do the first no problems but its the 2nd card
thats giving me problems. I tried Rivatuner.. ATiTool... CCC
Thanks for any help and info......my cards are 2 HD 3870's
once cf is enabled in catalyst, you can go into the overdrive pane where there is a drop down that allows you to overclock the cards independently. i don't know about rivatuner.
