w@termelon
- May 17, 2008
hi everyone,
im new to this forum but not new to building computers. Since its summer and its REDICULOUSLY hot in my apartment, my gaming rig which i also use for school work is heating up my room even more.
so my solution is to build a smaller, "summer computer" so to speak. Ive pretty much decided on a shuttle XPC, probably the G33 based one becaues it wont break the bank at ~250 dollars.
I still want this computer to be a decent gaming rig and one capable of handling large tasks so the processing power needs to be there but i dont want to spend more than 500 total on the box so that leaves ~250 for HD, and ram, and CPU, i have an old 8800gts 320mb gfx card to put in there as well. im planning to stick in a 750 gig drive and 2 gigs of ram so that'll leave approximately 100 for the CPU. so basically im at the E2180 range.
i want to have the E2180 to be at 3Ghz preferably a little higher. So first question is, does the shuttle overclock well? anyone have a preferend shuttle model that overclocks the best? it doesnt have to be Intel based, an amd system would be fine too, but same type of standard applies (3Ghz+). Also how good is the heatpipe heatsink? i dont like my processor getting too hot. My E6550 @ 3.5Ghz is sitting at 28C idle and 40C max load in 90F temps right now, so i'd like to keep CPU temps below 50C under load. Anyone have any expeirence with this type of box?
thanks in advance!
thanks in advance!
