Overclocking IBM/Lenovo T60?
nst6563
I've googled around a bit and can't really find anything on the subject....but anyway, I just got this T60 and I *THOUGHT* the company was ordering one of the decent ones (Core Duo, 100gb drive, etc)...but instead I got shafted with a T1300 1.66Ghz Core Solo.
The system uses an i945GM chipset and the chip is a Yonah. Granted, the system is fast and snappy...but can I get any more from it? I've read about the pin mod...but this is already running on a 166Mhz bus...could I possibly pin mod it to run off a 200Mhz bus?
It already sucks that I didn't get the widescreen, biometric scanner, 100gb drive, and Core Duo...it'd really suck to not be able to oc this bitch and get more from it.
I'm thinking that a laptop won't have enough cooling to handle any overclocking. I would strongly reccomend against it, even if it was possible.
laptops are not meant to be overclocked - cooling is often BARELY suffucient to cool it at it stock speeds.
you can try CPUFSB if it supports the chipset.
Also i am sure you company would love to have to replace your laptop if you did overclock it. It is not your laptop likely, so i wouldnt fuck with it.
besides what do you do on your laptop that is so CPU intensive?
A) Not planning on any records here, just a little extra "oomf" when it's needed (that means it wouldn't be O/C'd all the time). And if it does get too hot, I'm not a noobtard that will keep it that way.
B)The cooling on this laptop seems very good at stock. I never hear the fan and the air that comes out of the heatsink fins isn't very hot - warm yes, hot? not really. this exact same laptop is offered with a dual core 2+ghz cpu and utilizes the same cooling, so it's got headroom to begin with for cooling.
C) I do plenty that is cpu intensive and I do multitask a LOT...which is why I was let down it wasn't a Core Duo. There are times when I'm running 3-4 "hydra" type scripts I've made in the background plus another in-house multi-threaded app. Most of the time, that happens on or around "Microsoft Tuesday" though, which is why I would like the extra "oomf" because quite often I'm able to peg the cpu to 100%.
If there's no way to o/c it, then I'll simply just get a T2400 and swap the cpu out.
thas kew, just making sure :)
i would say if it wasnt under warrenty to take it apart and replace the thermal past e with some AS5, i did that on my dell inspiron 9100 and now i almost never hear my fan rev up even running 2 F@H.
find out the chipset and try out CPUFSB.
ok. I tried clockgen but that was a no-go :p
as for the cpu, I assume it's possible to swap out the CPU with a Core Duo right? Since it's got a Core Solo (blah!) already it should just be a simple swap?
It does run decent for average use, however I was trying to get away from spreading my work across 2-8 PC's on those certain M$ tuesday's where the security patches fubar 40,000+ machines in the enterprise :p
