Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
also when testing your overclock use linx run 25 for basic stable and then run 50 to ensure for total system stable.
also here is link for bsod codes this is a guide which will show you each bsod will have a number at the end and this will website will tell you what you need to increase
