You can just try in AMD Catalyst (the control panel). It's called "AMD Overdrive". Just bump it up in 50 mhz increments, one at a time (do core speed first, then memory).
Test stability using OCCT, MSI Kombustor, or Heaven. If it runs fine, bump it up another notch. When you start to artifact, bring it back down to the last good setting. It may very well run at the OC version without a hiccup.
