Hello
So im basically trying to reach the limit of my 3800x2, Im currently stress testing it @ 2.8ghz @ 1.5V. So far the load temps are under 50C. So lets see if its stable for more than an hour, then im a leave it stress testing overnight.
-But to the questions at hand, Anyone remember their old 3800x2 or people who still own them, what was your most highest clock with what voltage settings? I understand some batches clock higher than others, but im just trying to figure out whats a good place to leave it at.
-How much voltage is too much? Im guessing im hovering over the sweat spot?
-My motherboard currently is running @ 1123.8 Ht, Should i give a voltage bump or leave it if cpu is stable? Stock is 1k even.
-Im currently using the small FFTs option on orthos, if everything turns up stable on this setting, im good or not?
-One thing thats bugging me, is how hot my gigabyte motherboard runs (Around 71C), Is there any aftermarket cooler that is low profile but you can still have the newer cards on? My current 9800gtx is hovering directly over the cooler, so im guessing no?
thanks for any help, i have been running my 3800x2 stock for a bit, so might as well overclock the hell out of it, before i upgrade to a newer rig early next year.
