Starslayer67
- Aug 17, 2010
So I bought the 460's in my sig about a month and a half ago, and I love them. I then went NV Surround (5760x1200) a few weeks ago. Also, totally awesome. Now I've decided to try my hand at OC'ing, and that hasn't gone as well as I had hoped, or so I think.
So far, I've only tested it using DiRT 2 and Far Cry 2, not exactly the latest GPU killers I know. Anyways, in DiRT 2, I managed to hit 850/1700/2000, but not so in FC2. Since the artifacts suggested memory getting too hot, I backed it down, and got it looking stable with 830/1660/1925. However, after playing a while, some textures would stop loading properly (plants would turn white at night, people's arms would suddenly turn black, etc.), again suggesting a memory problem. So I backed everything down to stock clocks (720/1440/1800), and the problem showed up again, always after about 15 minutes or so. My temps have never exceeded the low 80's on the top card, and have never gotten above 65 or so on the bottom one, so at this point I don't think it's a heat issue, and may be an issue with FC2.
I am currently using EVGA Precision to control the clock speeds and for GPU temperature monitoring, and running the 260.89 drivers. I did not use Driver Sweeper this time, but it also showed up with the betas, where I did do the whole song and dance, so I don't think it's a driver issue either.
Side note: any good programs out there besides Furmark for continuous stress testing? If I could run one of those, it might help narrow the issue down.
EDIT: Oh, one more thing. I decided to run Furmark again at stock clocks for my cards, using 4x MSAA, 5760x1200 fullscreen, post-processing, and displacement mapping. After about 25 minutes, my top card hit a steady 95 C, while the bottom hit a steady 71 C. I don't know if the temperatures had finally stabilized, because at that point I shut it down to prevent any possible damage to the top card. In light of this, do I need better cooling to even think about overclocking, or will the stock coolers be fine? Like I mentioned above, in game, I never exceeded the low 80's on the top card, even after playing for a couple hours.
