I just got the rest of my components together, put everthing together, and here is what I have so far. Without a lot of voltage I'm having a lot of trouble in getting the clock high and running orthos for more then a few minutes. At 1.55Vcore and 3.6Ghz I can't boot into windows, or at least if I can I'll BSOD after a few seconds of orthos.
I have a couple of questions... I have Vcore set to 1.55v in the Bios, but it is reading 1.238 in CPU (under load), is that normal? How do my load temps look? I haven't really started to touch the memory, is that what I should do next. I realize I haven't run a long Orthos yet--- but I'm impatient. Should I tighten the RAM timings, or increase the speed?
Thanks!
Here are the specs and bios settings / screenshot. Any advice (or what to do next) would be appreciate.
Intel C2D c6420 -- L644G449
eVGA 680i SLI 122-CK-NF68-A1 w/ P27 Bios
Tuniq Tower 120
OCZ2N1066SR2GK - 2GB DDR2 PC8500 1066MHz 5-5-5-15
Vista Home Premium 32bit
Clocks and Timing
FSB - Memory Clock = Unlinked
FSB (QDR), MHz = 1750
MEM (DDR), MHz = 800
tCl = 5
tRCD = 5
tRP = 5
tRAS = 15
Command Per Clock (CMD) = 2T
tRRD = 3
tRC = 22
tWR = 5
tWTR = 9
tREF = 7.8uS
System Voltages
setting current value
CPU Core = 1.5500 1.51V
CPU FSB = 1.5V 1.5V
Memory = 2.100V 2.100V
nForce SPP = 1.50V 1.50V
nForce MCP = Auto 1.500V
HT nForce SPP <-> MCP = Autp 1.20v
System Monitor
CPU 44c
Board 33c
MCP 43c
cpu core 1.51v
cpu fsb = 1.48v
memory = 2.1v
+3.3v = 3.26v
+3.3v dual = 3.26v
+12v = 12.24v
+5v = 5.06v
+Vbat = 3.02v
Thanks!
Tuniq Tower 120
Clocks and Timing
tCl = 5
tRCD = 5
tRP = 5
tRAS = 15
tRRD = 3
tRC = 22
tWR = 5
tWTR = 9
tREF = 7.8uS
System Voltages
CPU FSB = 1.5V 1.5V
System Monitor
CPU 44c
Board 33c
MCP 43c
cpu core 1.51v
cpu fsb = 1.48v
memory = 2.1v
+3.3v = 3.26v
+3.3v dual = 3.26v
+12v = 12.24v
+5v = 5.06v
+Vbat = 3.02v
