Overclocking CPU while having a SATA hd..
Mr. Stryker
Please correct me if I'm wrong, but if you planned to overclock the CPU, the first two SATA ports would be affected, right? Because you increased the HTT/FSB that is also affecting the speed of SATA ports 1 & 2. But the problem is I have two SATA ports on my motherboard, do I have to use an EIDE hard drive if I wanted to overclock?
Overclocking will affect ide and sata hard drives if you can't lock the bus speed.
