Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
When experimenting with overclocking I found that on my motherboard (ABIT IC-7) with a P4 2.8C CPU, any clock speeds over 220 causes my HD (10k RPM 36GB Raptor) to fail detection on the SATA bus.
Also, if the SATA ports are native on your chipset, they're from the southbridge, which is unaffected by PCI lock. If that's the case, you could get a SATA card
