Overclocking Corsair 3200C2 RAM
ScretHate
First of all, how much voltage can I give the RAM without damaging it?
Second of all, what kind of overclocks have you acheived with this RAM? So far, I'm able to go to 210 @ 2-3-3-11 stabely, so I'm curious as to whether I'm near my peak or not.
Thanks.
2.9v should be fine. (I've seen people run 3.1v+ for months on end without hurting their ram)
Can you tell me the exact code of you RAM? Do you know if you have BH-5 in your ram? Do you have a vdd mod on your 8rda?
You'll probably get a max FSB OC of 210-220 FSB without a vdd mod.
I have a revision 2.1 board, so I have my vdd set to 1.8 in the BIOS. I'm not quite sure about the RAM though, I'll look at the codes as soon as I'm through with my school work.
i was not able to push my ram any higher then 210. relaxed the timings and threw all the voltage at it i could with this mb (rev. a).
