Hey guys, I just recently completed my high performance gaming PC and am now looking into overclocking and getting everything stable, etc.. and I need help.
I have never done this before, so I'm a complete noob at it, and I got several questions, and am looking for the best advice I can possibly get from any and everyone.
After some good research I've seen that these chips (3930k) can acquire some pretty high and stable overclocks (4.6-5.0ghz) and I'm wanting to do this myself, if I can figure out how. I'm not quite sure of everything, or if I'm doing it right, but at this moment, I have came across this current video:
http://www.youtube.com/watch?v=cdypzNu4He0
I have copied his bios by manually entering everything I could tell that I had different, and I'm wanting to know what I could do, or if I did everything right and should leave it as is..
My specs are as follows:
CPU: 3930k
GPU: 2-WAY SLI Titans
MB: ASUS Rampage IV Extreme
RAM: 32 GB 1600 CAS 7 Gskill Memory
Right now from copying his bios I have it running at 4.7ghz, at 1.392 Core Voltage.
I ran intel burn master on the highest setting and it said that I passed.
I also ran prime 95, and it passed.
My current temps are around 40-45 stock, and was ranging anywhere from 70-78 on full load when running these temps. I'm not sure if these are safe, if I should keep what I got, or approach another route.. being that I'm completely new at this I could use all the advice I can get.
For cooling I'm using custom water cooling, 2 separate loops. The loop cooling the CPU/MB is a modded h80i radiator with push/pull fans.
For the gpus I got a 240 radiator. I haven't overclocked the titans yet, but I want to as soon as I finish and find out what I should do with my current CPU situation.
I have some pretty crappy 1500 RPM fans I'm using on the radiators, but I just ordered some of the corsair high edition 2350 rpm fans, and will be using those as soon as I get them.
Look forward to some advice/help.
Thanks guys.
CPU: 3930k
Thanks guys.
