Maximillion
- Aug 16, 2005
I hope this is the right place to post this. I have a Winchester 3000+ 939 socket that is at 1.8 stock on a MSI Neo2 Plat with 1gb Mushkin dual channel RAM.
The way I overclocked is I lowered the HTT mulitplyer to 3x. I turned off dynamic overclocking, set my AGP frequency to 67mhz, locked my RAM to 166mhz, set the RAM timing to 1T, and set the FSB to 250. I am now running perfectly stable at 2250mhz with 33 degrees idle on stock cooling.
My confusion comes in the BIOS. Under the RAM settings it shows its running at 333mhz. Shouldn't it be around 400mhz? How do I make everything run "sync" with each other?
