Overclocking and Standby problem
Adidas4275
I have the rig in my sig and i am in the process of making a media server to take my tv recording duties..
I want to have my main rig in standby mode so that my firefly remote can wake it up. (it works i read in the snapstream forum) the wake isnt the problem.
the problem is when it wakes the OC is reset and everything is a stock.. 200HTT
does anyone else have this problem?
can other people who OC put thier PCs in to standby and see if it resets your OC?
maybe its a setting in my Mobo settings... i will try dfi-streets aslo
but does anyone have any idea?
I assume your OC's are in the BIOS?
When in standby, how long do you normally stay in this state? Go into standby, and QUICKLY come back out (like, 2-3 seconds TOPS) and see if your settings are changed.
If they're at the regular setting, it's possible that your CMOS battery is dead.
If there still at your OC setting, then it's possible you've enabled a power state, that takes power away from the mobo on sleep. I dont know what this state is called, I just know it exists... ACPI or something?
hmm interesting....
yes my OC is in my bios
and when i turn it off and then on the settings are the same.
ill look at it tomorrow, maybe my CMOS bat is dead
thanks
Yeah, that happened to me once, freaked me out for weeks.
It was on a client's computer too, so that was really uncool.
Adidas4275 said:
hmm interesting....
thanks
hook up a multimeter to that battery to test it - bet that's your problem - keep us updated
