Overclocking an Athlon64 3000+
J
JSClark
Guest
I'll probably want to get a couple extra case fans as well as a bigger HSF I assume...
As most reivews show oc'ing is all FSB. and outside the stock dividers you'll end up be running PCI and agp out of spec.
but generally you'll up the fsb to prolly 215 maybe 220 if your lucky .
So I just adjust the FSB a little at a time to OC the chip? You also mention PCI and AGP being out of spec when doing this, will this affect any cards I have plugged into those sockets??
yes, I am a newb when it comes to OC'ing :D
It will effect the cards you have pluged in. If you go too high they won't function, or just act real odd.
