Overclocking amd x2 3600+ Two differnt cpu temps? which one is correct.
vvilliamm
im currently using cpuid Hardware monitor says both cores are around 12 degree Celsius, when i download Core Temp it shows that both of my cores are 30 degrees Celsius.
my current volt for cpu is 1.30
my stock speed is 1.9 i overclocked it to 2.0 lol not alot but i have an question if i overclocked it to 2.3 ghz with the same voltage of 1.30 will the temperature change or stay the same as it were on 2.0? cause i heard that voltage determines the cpu temps.? i've overclocked it to 2.3 before with 1.3 v
30C sounds right.. use coretemp.. or speedfan.. either one of those.. cpuidhardware monitor isnt always that great..
the temps will change but very minimal.. maybe 5C at most at full load.. idle temp will stay exactly the same..
