overclocking a coppermine cpu
desrin
I have a 866 coppermine cpu with a plain coolermaster fan and one exhaust fan in the case, how much can i overclock this sucker?
What board, Your not going to go too far since this is a 133fsb cpu and a lot multi. even if you can get it to 160fsb, that's only 1040mhz 6.5 multi.
Last P3 coppermine i had was a 750 100fsb, it would do 155 with an alpha slot 1 Heatsink. 1162mhz
That's a hard cpu to clock that your using.
its pretty hard to gat coppermines over 1000 anyways.
I have 2 coppermine CPUs - one 500Mhz that's capable of running at 750-775. The other one is 600MHz and runs at 800-840... But those are 100 MHz FSB cpus and those are much better overclockers than the 133 FSB models...
I had 2 coppermines... (both slot1 - 100FSB cpus)
a 600e that would do 900Mhz
and one 700e that would do 1050Mhz
Both were limited by the mobo at 150FSB (or maybe ram)
But the limit on most coppermines is around 1000-1100Mhz
