Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
What you CAN do is check the clockgenerator on the motherboard, get the part number and then check out a program called CPUFSB (google should take you straight to it) to see if it supports it.
I did this with a Dell Optiplex GX100 recently.
A lot of the big manufacturers use clockgenerators that don't connect to the SMBUS, which is how a lot of the software fsb programs (like clockgen and cpufsb) read and write to the clockgenerator. This is why most of the software fsb utilities also don't work.
