overclocking a 939 amd64 3700+
Tx3kgtman
Ok im new at the board and i like what ive seen on here. Im just learning how to overclock and ive only got my cpu from 2.2 to 2.4. Im water cooled and my mobo has alot of setting but i not sure what most do. cpu voltage, agp voltage, dimm voltage, multiplier and tons more. can anyone guide me thrue to overclocking more than 2.4 cause anything after that it locks up. but im only changing the fsb. the multiplier is set to 11.
please be more specific (what tools you are using)
i recommend you read the overclocking guide in the amd processor forum
mine is stable on air (zalman 7000b cu) @ 2.8 with 1.5 vcore
i got clockgen, prime95, and speedfan, and followed the guide.
its written by cf Eclipse
also if you have a ausu mobo dont use the oc utility...it is crap.
