Overclocking a 7900GS from ASUS
coolsteef
Hi everybody,
I've got everything I wanted in my case and now I've began to overclock my
ASUS card. (a Silverstone FM122 12cm case fan 107CFM)
The Silverstone can really freeze your stuff.. Eventhough my room temps
might be around 22C it feels like 16C on my hand when it goes at full speed.
Makes a hell of a noise but it's just for testing.
The thing is.. After installed Coolbits 2.0 I got an option in my Nvidia Panel
called Debug Info. It says numours of time it clocked my HW down cause of
high temps. I really don't know where the software gets its info off but I'm sure
it's false. Ati tool says my temps won't go over 45C. And I achieve that just
with my Fatal1ty FC-ZV9 on performance mode. With my case fan blowing
on the card too I expect it will be not any higher. How come Nvidia thinks
my card is overheating? In Smart Doctor I unchecked the option Overheating
prevention. It is just impossible my card is overheating.
My maximum Core = 568mhz (only 1 mhz higher and it says overheating)
My maximum Mem = 820mhz(Setting it on 840 makes no difference isn't that
strange too?)
