overclocking 939 platform...
Xenozx
ok heres the deal, im looking to build a new system and im interested in the amd 939 platform. im looking to go with a 3500+ (guessing its a 3800+ underclocked and a lot cheaper) so i can overclock it. The only thing is i dont seem to be able to find any heatsink/fans that work with the 939 platform? are there any currently and if there are what is a good one for overclocking? can someone link some good ones if you have the time. I like the slk series of heatsinks but so far i dont believe they fit the new platform yet. any info/links/help would be greatly appriciated.
The 3500+ isn't a socket 939 from what I know. I think it's a 747 (or a number around there).
Edit: This stuff is too new for any HSF to be out. If you're going to get one though, get that one that looks like a jet engine or somin. It's supposed to be great.
3500+ is socket 939... and in theory any socket 754/940 cooler will fit on socket 939 mobos... the socket dimensions are all the same and they have the same mounting hardware ... only the pin count is different.
Swiftech has a solid offering along the lines of the rest of their copper base/aluminum pin series. Nothing from thermalright yet that I'm aware of.
as far as i know s939 uses the same hsf mounting style as s754 and s940.
yeah a 939 will use the same cooler as a 940/754 (same size/same mounting bracket) AFAIK.
thermalright has the 948U (fairly certain) on a64, swiftech has their mcx64/6400, alpha has the pal8150 and maybe some other stuff as well.
