What tool should I use? My Asus 5850 is on water, so temp is not a problem. Asus bios is pretty good, the only limitation is voltage. Although it does come with an Asus in house software to overvolt it, but I find it not worth the trouble to as the interface is sub-par and cause some annoying issues.
Can you guys recommend me an alternative OC tool that allows overvolt? And what is the max voltage/temperature this card can take?
