Does Rivatuner allow 2D/3D overclocking? If you select "Low Level System Settings" for each GPU under the "Main" tab, and then click "Enable low-level hardware overclocking" and change the frequency, does that change both the 2D and 3D clocks or just the 3D?
Right now I have clocks maxed out in ATI Overdrive at 800core / 1000(4000) memory. Is there any reason to use Rivatuner to go higher. Can I get 4400 out of the memory or any more out of the core?
If so, what is the correct way of overclocking a dual GPU like the 4870x2 in Rivatuner?
Thanks
Thanks
