Overclocking 3770K (voltages question)
  • Thread starter Deleted whining member 223597
  • Start date
D
Guest
So I decided it's time to actually OC this 3770K since stock is getting boring and I got a K processor to actually OC.
Anyways, I started off simply by just adjusting the Vcore and multiplier. 4.5ghz @ 1.25 volts which doesn't seem amazing but it'll do for the first try(1.2 crashed on startup and 1.22 crashed IBT/Prime95). 10 runs of IBT and the max temps were 83C on the hottest core (Room temperature is about 26C).
Now my question is, what else is there to change with Z77? I see lots of other voltages, such as PLL, and am wondering what exactly to do with these? Are any other voltages/settings important? I am using the Gene-z.
