Overclocking 2500k on stock cooler
Ryan930
What's the minimum you would have to overclock a 2500k to notice a difference, and can you do that on a stock cooler? I know that I could get a cheap 212+ but I'd rather save my money and not OC at all.
Doing what?
The stock cooler is adequate for stock speeds. You should try to keep the CPU under 70C, and certainly not exceed 80C. Results will vary; you may or may not be able to hit 4.0GHz without exceeding 80C. It will get pretty damn noisy. Use prime95 and RealTemp for load temperature testing.
I would be impressed if the stock cooler stayed under 80 running IntelBurnTest.
As usual my response is.... people actually run the stock cooler?
I throw them in a drawer or put em in the recycle bin.
A 212+ is so cheap and you can overclock to 4.5 or so with it. The stock cooler just throws hot air all around in your case. I like the aftermarket HS's that throw air into the exaust fan which is what you really want?!
Yeah I understand, but like I said I'd rather save the money. Being a college student most of my money is going straight to food and rent
Thanks a lot for the input everyone:)
